I need help building a barn!! 10.8m x 30.5m
The ground is clay, What is the best way to dig the base?
1. Excavate 11 inches and then put down 6 inches hardcore and then 6 inches concrete. steel strengthend. or
2. Dig 6 inches down all over. then dig to a depth of 600mm on the external walls. was told that this could be filled with concrete which has stone mixed in already so minus the hardcore!
What is the best and most economical??
I wanted the walls to be made out of blocks. what types of block would be best as they need to be strong as they may have animals knocking them. to strengthen the external wall there are partitions which can be interlocked into the external wall to strengthen.
with regards to the roof what would be the best way to do it using steel corrugated sheets.
Thank you for any help!! I really need it!!
