Question: the original bath cold water supply (mains pressure) is 22mm but the hot water supply is 15mm should both be 15mm or both 22mm If not why not - balance/flow issues
I have a Vokera combi boiler.
I'm intending to fit a "Hudson" type thermostatic valve (wall mounted) to supply a bath Centrafill and ceiling mounted "rain-shower".
I am planning to use PEX pipes for the run from the valve to the outlets.
The valve requires 3/4" x 22mm or 3/4" x 15mm outlet adapters for connection to the pipe run.
Grateful for advice.
Ron
Ron
