guys,
I just temp fitted my bath, when all is adjusted at right height ( for panel ) , I can ONLY manage to fit in a SHALLOW bath waste.....
and I mean, theres about 10mm clearance between the bottom of the waste S bend ( or whatever its called ) and the floor......
the main waste pipe goes straight in and out of the house wall, is it OK to use the SHALLOW waste pipe ?
someone said that you must use a bottle type trap on the bath, if the waste goes out directly into main soil pipe.
well, i cant fit anything bigger than this one,
will it be ok ? or will i have problems with the water being syphoned out of the shallow waste pipe ?
cheers
cheers
