Hi all,
I am a fledgling corgi man and have been called out to a Baxi Combi Boiler 80 e which is constantly losing pressure i.e. from 1.0 bar down to 0.2 in a couple of days.
I work for myself so dont have the safety net of work colleagues with years of experience!!!! Hence my plea for help!!
Checked Expansion vessel charge - 1.0 bar
No leaks from PRV-
Pressurised system to 2.5 bar and checked all rad joints etc for leaks. None evident.
Thought there was air trapped in the system as the highest rad wasnt heating fully. Closed off all other rads and forced heat up to it.
Automatic Air vent is open.
Checked all rad keys to make sure they were fully tightened and not drawing in air. Re topped up system.
The system has a secondary expansion vessel fitted as there are lots of rads.
So where else could i be getting air in/losing water?? A lot of the pipes are concreted into the ground so it hard ro check for leaks apart from rad joints.
Could it be a leak in the combustion chamber which is evaporating??? How do you check this??
Any other things i should be looking for??
Top forum by the way. It has pulled me out of a few holes so far!!!!
Grill
No leaks from PRV-
Grill
