Hi all,
Realy hope you can help me with this as its been getting on my nerves for a while now.
I have a baxi 80 eco combi boiler, it all works fine when the heating system is cold. As in, if i switch the central heating on it fires up no problem and the same with the hot water, fires up fine.
The problem that i have is when the central heating is on and it gets up to temp, the flame goes out. (which is correct i know) but after this it wont relight again. The pump and fan keep running but theres no flame ignition. If i turn the hot water tap on, it wont light either.
I have to wait for the whole system to go cold, and then it will be fine untill it gets hot again.
I've tried resetting it on the switch on the front and also the little switch on the safety thermostat but it doesn't help.
Its had a new temp sensor and also a flame sensor but with changing these it hasn't helped atal.
Any ideas much appreciated
Mike
Mike
