Though our boiler works, it does so inefficiently.
When we increased the temp by turning the Central Heating Temp Control to max' in November last year we noticed a change in the boiler's actions.
When the boiler is switched on the 'Burner On' indicator lights up and the water temp increases as shown by the 30deg - 80 deg indicators. The sound of the boiler is evident but is accompanied by a fast ticking noise. The 'Burner On' indicator and boiler itself go off after 2-3 mins and the temp indicators show a decrease in temp as one would expect. After 3-4 mins of inactivity, the boiler restarts.
The boiler functions in this way for anything between 12-15 hours and then appears to stabilise without any further cutting off. In other words the 'Burner On' remains on and the temp gauge shows a constant 80 degrees.
Whilst this is irregular and may be causing greater bills than necesssary one of the most immediate problems is the ticking noise from the boiler.Each surge caused by the boiler switching on causes the aforementioned ticking at the boiler.However this then affects 4 radiators ,which 'tick' incessantly, as the surge passes each one in turn-every 3-4 minutes for 12-15 hours until the boiler remains constantly on.
Our boiler was fitted last year, Feb 17th and had the obligatory 'Flush'.
Thus we do not suspect a block at 4 radiators on 3 separate floors.
Further, when the boiler finally remains on, after 12-15 hours, the ticking at both boiler and 4 radiators ceases.
Any suggestions
Any suggestions
