We have a Bermuda Back Boiler which must date back to the mid 1980s and generally it works fine and is serviced yearly but now it is getting warmer we have gone to the Water Only setting and now not getting any hot water!
If I have the setting on Water + Heating then it fires up fine and we get both heating and water but when on Water Only it tends to not fire up or fires up rather pathetically or if it does fire up properly you hear a boiling noise within a few minutes and then the flame goes out.
Any ideas what this is? We've always had a problem but generally it settles down and behaves on Water Only but not this time and I can't keep having the heat on!
Incidentally we had the Hot Water Cylinder replaced a couple of weeks ago.
So should I get the plumber or the boiler repair?
Thanks,
Phillip
Thanks,
Phillip
