hi can some one please tell me the best adhesive to use to fix a upvc window sill to brick work and the best adhesive to fix upvc trims to the frame work
We use glue and activator for all trims, double sided tape works as well.
Depending on the gap once the sill has been levelled, either silicone or foam
Eurocell have branch's all over the place and there prices are reasonable. Stay away from the diy stores as their stuff is generally poor quality and over priced.
