Ok experts, are you ready for a headache..or perhaps help cure mine and point out the fix. I'll try and keep this simple and precise.
The above boiler began cycling off and on and would not supply DHW unless CH dial was turned up (ie central heating on full)
This eventually led to the lockout/shut out light coming on. Once the reset was pressed the boiler would restart but do the above again and
supply DHW
Now, I have a few spares for this M90F boiler, so I decided to just swap out both circuit boards. The result was the boiler operated better but very similar to before. ie it still cycled off on but remained stable for a bit longer...confusing?... it gets worse!
To check the fan, I removed the combustion cover AND guess what.. the boiler WORKED perfectly!! DHW and Central Heating! I tested it a few times to make sure and yeh it worked perfectly. Then after replacing the cover the problem returned!!! BUT the lockout light now comes on and will not reset, whatever I do!!
I then tried reconnecting the old PCBs but the lockout light remains stuck on
So I am massively confused and frustrated. Something is causing the total lockout, that's for sure..but I'm not sure what.
The last thing I did earlier tonight was to undo the pump bleed screw and water gushed out which suggests a busted pump (pump spindle rotates easy) as only a few drops should trickle out so there's another possible fault. But I've no idea whether I've got multiple faults of just one...
I'm not sure where to begin due to the confusing results. I know there are proper experts on here who fault find all day long and I'd be very grateful or your input and advice.
Cheers guys!
BTW my dad was a plumber/heating engineer (long dead and RIP) I was sweating lead to copper joints using tallow, moleskin and a paraffin blowlamp over 45 years ago! For the record, I am a highly skilled and vastly experienced plumber but have never been CORGI/Gas safe registered, hope that doesn't stop anyone assisting me.
supply DHW
Cheers guys!
