BIASI Gas Boiler - pressure issue?
21 Nov 2006
Hi
I would like to know what the pressure setting is for a BIASI Gas Boiler (24S) as my boiler has a reading of zero on a scale that goes up to above 3 Bar when the system is on! The black indicator stays at zero whilst the red indicator is at 2 Bars - is this what itshould be or was in the past?
The system heats the water and radiators well downstairs but less so upstairs. The bottom of the radiators being warmer than the tops. The hot water is also not very hot and only last for a short time before going colder.
How do I fix this problem?
Excuse my ignorance/lack of experience on this issue!
Any advice/suggestions welcome - thanks!! - the system has been like this for the past 2 years!!
Expansion vessel needs pumping up to around 1 bar then put in 1 bar pressure @ guage so when system water is heated the increased pressure can be accomodated & not go t 3 bar
Thanks for the quick reply - much appreciated!
Sorry for this question (if it seems silly) but where do I locate the expansion vessel/what does it look like and how to top it up to 1 Bar?
Any help welcome!
largy
Have managed to pump up the pressure to 1Bar from the expansion vessel. How do I add another 1 Bar at the gauge?
I was going to suggest you moved the red pointer to 1.5 Bar and then it should have worked fine.
You've probably done it wrong. Try reading the FAQs topic - I think it's covered there.
