Biasi M90E.24S lockout problem
16 Feb 2009
London
Hi, all. I'm having a problem with my gas boiler, a Biasi M90E.24S compact combi. Here's a pic of the control panel:
When the hot water tap or central heating is turned on, the gas fire ignites and burns for a few seconds, then stutters for a bit and goes out. The red lock-out lamp turns on.
There is a reset button next to the lamp which seems to work, but when hot water is turned on again the same problem happens again.
I also notice that the green application light flashes on and off constantly, I'm pretty sure it never did that before. Pressure is at 1.3 bar.
I had this problem about a year ago, and using the red reset button fixed it, but that doesn't work now.
Any advice about what I can do about it appreciated!
