I'm intending to completely renew my driveway which is long enough for three cars in line, but very narrow, so I'm excavating about 1m to the side from a raised front lawn, and will build a small brick retaining wall. The nett addition to the driveway surface means that I will need PP unless I either provide drainage in the form of a soakaway (or similar) or use permeable blocks on a substantial bed of MOT Type 3 or similar.
My problem with the latter is that the driveway slopes towards the road and we have quite heavy clay subsoil. So I would expect that most of the rainwater would immediately flow to the base of the driveway, and spill out onto the road, defeating the object of having permeable blocks.
I wondered whether excavating a soakaway at the base of the driveway itself (adjacent to the footpath) would the the best solution, and use either a drainage channel to catch surface run off from normal blocks, or to lay one pack of permeable blocks at the bottom of the slope, and standard blocks over the remainder. I was thinking something like 600mm x 600mm, the full width of the drive (c2.4m). Does this sound workable?
