Hi, I went round to my brother in laws house because he had a very slight leak from one of his living room rad valves. The plumbing has recently been converted to a sealed system with the F&E tank taken away and replaced with an expansion vessel.
Back to the rad, I closed the valves either side of the rad and opened the air vent. I then opened the nut and drained rad into bucket. I put PTFE tape round the valve thread and tightened back up.
Here is where I think I might have messed up a bit. On refilling the rad I opened the control valve (I think its called) first and heard the water rushing into the rad and pushing the air out the vent. Once the water started comming out the vent I closed the vent and opened the lockshield valve. I never opened the filler (washing machine type valve at exp vessel) at this stage and the pressure guage dropped from 1.5 bar to just below 1. I thought 1 bar was usually ok for a sealed system so I fired up the boiler to see if everything was working OK. After about 15mins of waiting there was no heat coming from any rads but the flow pipe from boiler was hot and the return was slightly warm. At this point my brother in law said that the pressure should be up at 1.5 bar and proceeded to open the filler while the CH was still on which might have been the wrong thing to do. He closed it again when the guage had moved up a bit and we waited about another 10 mins for the rads to heat up before realizing that the boiler was actually off even though the timer was set to all day. We switched the timer to off and I checked to rads which were still cold. I went all of them and bled them and all bar one was full of air, we then topped up the system with fresh water . Now the situation is that all the rads are bled and full of water but the boiler is completely dead. When I switch it on at timer nothing at all happens, I also turned up the boiler stat to see if that would fire up the boiler but to no avail. I dont know if it is just a coincidence that the boiler stopped working at this time of if it was something we done (more that likely). The CH has only been on a couple of times since the plumber changed the system and my bro in law isnt sure if there was heat coming out of all the rads anyway before we started so we are unsure if it was something we done that caused there to be so much air in the system.
It is quite an old looking oil fired boiler btw, not a combi or anything like that.
Sorry for the long post
