I have a Vokera easy heat 25Ci LPG that alarms out after a minute or so, engineer has investigated and decided the flame sensor was at fault so fitted a new one but the fault remains. In the minute or so the boiler is on it repeatedly fires up then stops before eventually faulting out after about 5 attempts. Fan and pump are fine - rads or water get warm while the boiler is trying. The engineer now says it needs a new PCB but that's a lot more than the sensor and I'm not confident he's right.
Any thought on other things to try before I fork out for a new PCB?
