Hi all,
Moved into new flat in need of major refurbishment, so money's mega tight!
No gas supply, and storage heaters (which are fine), hot water comes from an unvented combination cylinder (big cylinder with expansion vessel on top?). Cylinder works fine, loads of hot water, only problem is the flow, which is bearable at the kitchen sink, but at the bath it's pathetic. I thought about getting a booster pump like the salamander CT50 but after speaking to salamander they said it can't be used with my type of tank, as it would cause it to implode!
Any ideas? Can't afford an electric combi boiler at hundreds n hundreds of £££'s, so all suggestions very gratefully received.
Thanks.
Dave
Thanks.
Dave
