bosch classixx 1200 "spin problem"
15 Jan 2008
Glasgow
Hi has anyone had this problem.
The machine will go through the cycle as normal but when it comes to the spin function it stops and the spin light on the display flashes and will not spin. Even when i select spin only the same happens. Any help is welcome. Thanks.
the machine was still full of water, so i opened the door and had to remove soaking clothes and empty the drum manually
pump blocked
try removing the drain cap at the front bottom of the machine and see if you can see anything blocking the pump.
be ready for water on floor !!!!!!!!!!!!!!!
Neal
Hey Presto!!!
2 coins and a curtain hook were lurking there. Tried it on a couple of programs and all seems to be fine. Many Thanks
