My Bosch KSR32623 frost free larder fridge is about 2 years old. It started leaking water from the bottom left front. This stopped a few weeks ago, the it began freezing everything. I have bought a thermostat but can't see how it is threaded through from the top front of the housing. I have removed the plastic trim that holds the thermostat. This is now dangling by the electric wires. I can see how to remove the actual thermostat assembly BUT can't see where the sensor is located after it passes through the front of the housing. I have removed the light fitting and can see a black plastic backplate (?). When I jiggle the sensor I can hear a noise from the right hand side of the fridge so I assume that the sensor passes somewhere down this side.
I have looked online for a repair manual without success.
Your suggestions and advice would be much appreciated. [/b]
