I am building a wall to fill an opening in a 600mm stone wall.The opening is about 2000mm wide and the new wall needs to go to the wall plate height of 3500mm.
I have been laying 4 inch blocks flat and joining the two leaves with a block across every block length.
What I was thinking of doing was when I get to the height of the 1st floor beams (2300mm) could I just lay 6 inch blocks the normal way,up to the wall plate on the outer leaf only or would this cause problems later on?
Also will I get damp problems doing this?
