OK, so I have a bit of a conversion project on.. A brick built shell with some additional steelwork supporting the slate roof. The walls are an internal skin of buff engineering brick and externally probably sandstone rubble and render. There isn't a cavity per se, and the walls are probably at least a foot thick, I haven't actually measured. Foundation depth and type are unknown. Building was built 1926.
In one gable there are 2 semicircular windows, the base of the semicircle you see in the below pics is 4 metres wide. the garage doors I've drawn are 4m by 2.4m. The base of the semicircle is 5 metres off the floor. The gable is 10m high at the apexes. The supporting steel for the roof is a large girder going from wall (above garage doors) to wall (opposite) with another 3 uprights supporting it at ~5m centres. From this, 4 sort-of-batwing shaped trusses carry large timbers that bear the roof and the other end of the batwing is buried in the front/back walls. The end of each timber (not drawn) also rests on the gable wall
It would offer me the most flexibility in terms of what I want to do with the rest of the building, if I could put 4 garage doors in this gable rather than 2, but I'm concerned about the structural aspect; this entire wall is about 25 metres long, putting 2 garage doors in under the windows would give 8 metres of this over to doors and keep most of the load in a vertical direction. Putting 4 doors in would be great, but that's 16 out of 25 metres gone leaving the remaining 9 metres to carry the weight, which would pretty much be acting at 45 degree angles instead, and I'm not keen on collapsing or putting stresses on that would push the front and back walls out of shape
Any thoughts? Sort of thing that need referring to a structural engineer?
View media item 59643
View media item 59644
Above is a drawing from google sketchup, looking at the internal skin of the gable from the opposite side of the building . If you want it spinning round and re-snapshotting, let me know
