I'm attempting my first plumbing DIY and have decided to swap my bathroom suite over.
As part of it I am removing a bidet and not replacing it so I will end up with surplas pipework.
Originally I was just going to cut the pipes back to under the bath (where the joint is) and cap them using a pushfit cap. However after attempting this I discovered that there is very little straight section of pipe available to do this. I have done it but have had to use plumbers mait to stop a minor leak due to the pipe being bent. and aren't really happy with this as a permanent solution.
So, my question is... currently there is a soldered T joint, I am assuming the "proper" way of doing it would have been to replace this with an elbow joint (the part of the pipework I want to keep needs a 90% bend). Is it just a case of heaing the joints, separating the pipes, cleaning and then resoldering if I wanted to do this?
