Hello, recently took off a radiator to clean all the sludge out. Also put in some cleaner into the system and have since drained the system at the same time took off the heat exchanger plate and cleaned out and topped system back up. Now non of my radiators are getting hot. Boiler out pipe to radiator is roasting. Getting to the first radiator by the boiler as this pipe is also hot but not getting into the radiator. Maybe a little bit as it’s slightly warmer than clay cold. I have bled all the radiators from bottom floor up to the top with no difference (a few times). I assume I have an airlock somewhere. Wondering if it could be after the heat exchanger and before the first radiator ie in the boiler itself? Would it be beneficial to drain the system again and top it back up?
Thanks in advance, should’ve paid someone to do it.
