Central Heating stopped working
27 Nov 2007
Hertfordshire
Although the domestic water is being heated the central heating water is not circulating. The pump appears to be running the boiler is working normally the programmer is on. I have the tank in the loft system type.
Does anybody have any clues as to the problem?
Thanks David
Sounds like divertor valve is not working. This is a valve that sends the heated water around either the dhw circuit or the heating circuit. usually located somewhere near the pump. If you find it there will be a lever which you can operate manually to test if heated water then travels along nthe heating circuit. Looks like a brass 'T' with a box on top.
Thank you alf.
I believe it is the motorised valve. The system has a Siemens MA-V322C which has been commented on previously on this forum. I have discovered I can purchase a whole replacement unit with the brass body or just the top electrical box which clips on to the lower part. I have pulled up the lever and water flowed so I feel that the purchase of the top box is all that is necessary. I hope I have made the correct diagnosis. This, hopefully, will be all that is required.
Trust it to go wrong during this cold weather.
