Hello folks
Our current monobloc kitchen tap is designed so the hot water is directed down a small separate plastic tube within the spout. For this reason it comes out with great pressure and splashes everywhere. If you turn it down to reduce the splashing the water just piddles out as it's such a small outlet. And the cold does not run in a smooth stream, presumably because of this tube in the way.
I mentioned this to a plumber who did some work for us a while ago and he said that all cheaper monobloc taps were designed like this as they were cheap to manufacture as there was no mixing valve to engineer.
Is he right? - and can anyone recommend a decent brand tap we could replace ours with which is not built like this? I can't see how to tell from a catalogue the type of construction used.
