Circulating pumps
3 Nov 2006
Bedfordshire
I have just changed a circulating pump on a sealed pressurised system which had failed due to water getting past the shaft seal and into the electrical area of coils and terminals. Since this appears to be a common problem with pressurised systems I was considering the next replacement ( if needed ) to be the type where the impellor is separated from the electrics by an impervious (to water) membrane. The impellor is driven by a rotating magnetic field that passes through the membrane.
With operating pressures of 2 bar the seal on the shaft of an "ordinary" pump has to be well designed and resilient.
Other than being less efficient and un-able to be "kick started" if they stick are there any other reasons why these membrane pumps are not used more often. ?
Bernard Green
Sharnbrook
UK
What the ferk are you talking about, the electrical bits are in a water tight tube.
If the pump is fitted correctly water will not get into the electrical dept.
UK
Sludge would stick the impellor and magnet may not have sufficient torque to move it.
