Can anyone help me, had a burst pipe over last weekend, pipe now fixed and all of a sudden radiators not working. Drained system, put inhibitor in tank, radiators working, now all only one out of seven working and it is not as hot as it use to be.
Turn off 'now all only' 6 other rads and the water should pump through to the 'now all only' other one which probably has an airlock in the pipework that leads to it.
Make sure the heating system is off when you bleed rads
