Coming home from work to find the boiler has stopped working. Fuse F1 on the Printed Circuit Board (PCB) has blown - Inspect the PCB to find no other suspected faulty components (the local engineer had resoldered a dry pin around 18 months ago).
Replace the fuse; check the pressure gauge (at 2); on the control panel,
set the boiler switch (DHW) to standby and CH switch to off.
Switch on the boiler - fan running (at slow speed) but as soon as I
turn the DHW from standby to on, the fuse goes. Replace fuse and try again but this time turn CH on first - no response; try turning on the DHW
and the fuse blow like previously.
The Fault Finding flow chart (electronic) in the menu suggests checking for a short circuit on pump, mains transformer, fan and gas value solenoids but I am not sure how ? Can some one help please ?
Any other suggestions is also much appreciated.
tonyid10.
tonyid10.
