i went to buy some elbow joints the other day but picked up compression elbow joints by accident.what i ar these used for just curious if i can use them instead of takin back
philipcooper said:what i ar these used for
so if i use them they will they make my taps run slower or fasterPaul Barker said:No they don't alter pressure they just alter flow rate. Presure is governed by the mains pressure or the hight of your cold water storage tank. To alter pressure you need a regulator. restricting the rate of flow makes no difference to pressure, but it does reduce the amout of water that flows at that pressure.
they are exactly the same as normal water plumbing elbows but just narrow abit in the middle.are u sure u cant use them on waterBamber gaspipe said:They can only be used on gas if the fitting is accessible after it has been fitted. i.e. not under flooring or concealed within a wall etc.
thanks for that answer i understand now cheersBamber gaspipe said:Sorry, you are misunderstanding.. you can use compression fittings on water, forget about gas, you are not interested in that. The only difference in a compression fitting & a soldered fitting is that if you are cutting into a pipe that has been filled with water & you need to rejoin this pipe to newer pipe then a good idea would be to use a compression fitting. The only reason for this is because if you try & use a solder fitting, because of the water that may still reside in the pipe, as soon as you apply any solder in won`t run or `seal` because of the water in the pipe.That is why you would use a compression fitting because you can seal the joint mechanically i.e. with a pair of adjustable spanners or pump pliers & adjustable.
