Hi all, new here. First thing to say is thanks to this site I have managed to add lights to the kitchen, hall haver moved and added sockets in lounge, hall, kitchen as well as moving cooker sockets and fixing the awful job done by the original sparky (new house build).
Original work left me with a 4ft length of twin and earth running at about 30 degrees to the horizontal from a double socket (it wasn't connected to the socket, just lodged inside the metal box!) and crossed over several vertical wires under the CU and ended about 3ft above the work service. Cleaned it all up and wiring now runs as per part P, Local Building Inspector has been round and is pleased with the electrics and I just need to get an electrician to test all sockets when finished - so that's the good bit. - Oh and thanks to all on the forums, lots of questions I had were answered.
Now the bad - I am a little stumped and confused.
Hall light has power fed to the lightswitch, with a second cable leaving which goes to the light fitting. It is a double switch and the second switch operates the outside light at the front of the house - so one more cable coming out of the box.
Power for the switch for the outside light seems to be taken from the live feed on the hall switch which is currently wired as one way switch.
I have a short live wire joining the C connections on both switches (as spotted in this thread by luminaire: //www.diynot.com/forums/viewtopic.php?t=97082
I have added two extra switches for the hall - one at the bottom of the stairs and one in the new hall to kitchen doorway. But I can't seem to change the existing wiring into a three way (well two way plus intermediate).
My wiring is currently like this diagram: //www.diynot.com/wiki/electrics:lighting:single_way_lighting:tblsnonharm
If you imagine an extra switch in that socket, the neutral from the right hand cable set (named as 'to next light' is connected to L1 on the second switch and the live is C on the second switch. There is then a little red wire from C on the hall switch to the C on the outside light switch.
What I want to do is convert //www.diynot.com/wiki/electrics:lighting:single_way_lighting:tblsnonharm
into //www.diynot.com/wiki/electrics:lighting:intermediate:chocknonharm bearing in mind I have to power the outside light from the inside of the switch. problem is if my understanding of the diagrams is correct, the live goes to L1 and the C is connected to the yellow wire which connects all the switches together.
Sooo if I connect as per the two way plus intermediate - if I connect the little red wire from the yellow on C on the hall switch - will this carry voltage and power the outside light?
Can anyone tell me in simple terms how to turn the switch in the first diagram into the switch in the second diagram bearing in mind there are 4 lighting cables entering this lightswitch (1. power in from main, 2. power out to lamp fitting, 3. 4 way cable to connect to other switches in three way set up and 4. the live feed out to the outside light - kind of like a spur I guess).
PS I also have mixtures of old wires (red and black, new ones which are brown, blue, black and earth and some which is red blue black and yellow - sometimes I don't see the wires it's just like looking in a kids kaleidoscope. At this point I wire it back how it was (two gang one way switches) and put fuse back in and look on here again
Lotys of similar situations, but none quite the same. Thanks peeps
