Conservatory Humidity
13 Mar 2007
Hampshire
Hi I have recently completed a conservatory some 3m500 wide by 2m500 deep. Floor is down, sills fitted using Duraboard and MDF skirting.
There is no damp in the conseravtory, the concrete base is sound and before the floor was laid I painted it using Drybase rubberised flexible DPM.
I must say this product was very good, easy to use and a good base. I painted up one brick high to be sure.
The humidity though is quite high, during the night the humidity (I have a digital meter) reads about 80%, this does seem quite high.
The conservatory has four top opening windows which I leave two of them in the locked vent position.
In the morning I am getting moisture in a thin bead along the bottom of these vents.
Is this a normal occurance? The thing is I can see a time in the winter when the windows will be running in water!!
Any help or has anyone else got a similar problem?
The door to our connie is closed between the months October through to March.
If you want a useable space all year round build an extension.
Conservatory is most ventilated space in a house since it's designed to be well ventilated, which means you were testing the moisture content of the outside air, should not be a problem, had mine 12 years and never a drop of condensation, except when the wife's got all three ovens going at Xmas.
Condensation is relative to the dew point and coldness of a material not just the air humidity
You could take the roof off the conservatory and still get condensation on the glass
You say you have just completed the project, if this includes a concrete base this will take probably 1 month per inch of concrete laid so a 4inch thick base would take about 4 months to dry out and you say that you have already sealed the floor so effectively sealing in the moisture this will make the drying out process even longer
