Thanks to all of you that have answered previous questions about my fence building project. Normally I’d just cobble together a fence but, as this is a joint project between myself and a neighbour, it has to be completed with a bit more skill.
I’ve got my posts in and am now about to fix the arris rails. I want the rails to look continuous rather than having them with staggered heights where I use a new piece of wood.
So, what is the best method of ‘butting’ together the two bits of wood? The timber I’ll be using is 47mm x 75mm from good ol’ Wickes. This will need fastening to 75mm posts. I was going to join the wood together using a half lap joint at the location of the post. Is this the best place for the joint or would mid-rail be better? Should the size of the overlap be 75mm or would it be better to do a shorter overlap (say 25mm) then there’s 25mm of full thickness arris rail against the post?
Does the above make sense?
Many thanks
Gordon
Many thanks
Gordon
