cooker/hob wiring
11 Jun 2008
Yorkshire
Hi,i am fitting a new oven rated at 2.1kw and a hob rated at 6kw,is it ok with regulations to connect the hob via 6mm cable to the control unit which has a socket outlet and use the socket to plug the oven in.
the supply cable from consumer unit is 10mm and around 10 meteres in length.
thanks for your time and help.
Dave
