oh dear. here we go . . .Krypt said:Kind of related:
I just got a new kitchen from Ikea and they also installed it - well a sub contractor did.
what ratings are the 2 appliances? anything below 3kw can be plugged into a 13A socket. does the hob use gas or electric to cook on?I tried to keep out of their way most of the time but noticed they changed my old cooker switch (massive red switch on it) to what looked like a normal 2 gang socket. They then plugged the new fitted oven and hob into this.
yes it is. if your oven or hob goes up in smoke, you need to be able to isolate it easily.I never thought it might be against any regulations until I just read this - is it a requirement to have an isolator switch above the worktop?
yes. Ask them when you will be getting the certificate for the electrical work they carried out in your kitchen, and whether they have notified the local building control, or their registration body, of the electrical work. Tell them they could be fined a lot if they didn't notify. Listen for the tumbleweed and the click as their handset hits the desk. Then phone Ikea and ask them why they use substandard subcontractors and allow them to do dodgy electrical work.I did find some of the other things they did a bit weird which I will mention when I give them a call on Monday - should I bring this up too
It may be best to have a registered electrician check out what they did, even if they do come back and "fix it", there are all sorts of horror stories related to kitchen fitters.
