corsa club heater/fan back lights
22 Nov 2005
Devon
just as one problem solved another found. Anyone have any idea where to find bulbs that light heater / temp and direction knobs on corsa club(1999). have half removed consol but nothing jumps out at me as light bulb holder any help appreciated
Hi
The Bulbs are located on the Central fan switch. There is a plastic spur that goes off either side of the switch that houses the bulbs. You need to remove the dash around the switch to gain access to it.
cheers
CJ
Many thanks. I managed to find the bulbs mind you, it does help in the daylight and with a reasonable amount of industrial language i tracked the lil buggers down.
