I have just had a new shower (professionally) fitted.
It's a Gainsbourgh 9.5kw. (model 965sdl)
The flow rate is pathetic, the temp knob has to be turned almost completley to the highest heat position to get the correct heat and this makes the water flow really really bad.
It replaced another Gainsbourgh (think that was 9.8kw) and the flow rate on this was 10 times better.
The service valve and stop cock are fully open (there was no problem with water pressure before)
Before I complain to the fitter if I ask for a high kw rated shower is this going to improve things??????
