- Joined
- 21 Oct 2003
- Messages
- 3
- Reaction score
- 0
- Country
Greetings. New to this world so apologies in advance for info I didn't add, or added that I didn't need to...
10 yr old bungalow with oil burner (non pressurised, small open tank in attic) integrated with back boiler behind a fireplace. Two worms in hot press, one from back boiler (joined to attic), one in parallel with rads to get h/w direct from oil burner.
Plumber came yesterday as h/w would not circulate and boiler cut off after a few minutes. Pump fine. He removed any air between attic tank and hot press worm, did some bleeding beside the boiler. Maybe other stuff. System working good-o when he was leaving . I tried again a few hours later - but boiler wouldn't come on . Can hear pump, and rattle coming from non-return valve (?) beside the boiler. When I turn off system, sounds like bubble rising from hot press area.
Any ideas? Do non-return valves fail (intermittently?) ? Something loose in pipe jamming the valve? Would a complete drain/refill of system make things worse, or better to get plumber to check out the rattle in case I move it? Any special notes on refilling a system to avoid trapped air?
Any help much appreciated!
- John.
- John.
