Draining Central Heating System
27 Jan 2008
London
Hi.
I'm away from my property this winter. My insurance company has advised that I should drain the central heating system. Is this the same as power flushing?
Thanks in advance for any replies.
Thanks for your reply Andy. I do know that there's quite a bit of sludge in the system. Does that matter? And approx how much does it cost to drain a system? 3 bed semi, 6 radiators, non-combi boiler.
Draining your system to be safe or having a power flush is completely different. You will also need to drain the cold water storage tanks in the loft and your cylinder.
Andy
Much better to just leave the heating turned on at a very low level IMHO - this will both prevent freezing, and prevent damp
Thanks. I would do this but earlier in the year one of my radiators developed a leak from a small hole due to sludge in the system. So I don't want to risk this whilst i am away.
Draining = emptying all the water out of the system so the pipes, tanks, cylinder etc are all empty (and can't freeze)/crack).
Flushing = pumping water round the system under pressure, and out, to flush out the sludge.
If you know it has a lot of sludge in it, and you are going to drain it, you might consider using a chemical cleaner (for a few days but preferably weeks if you use X400) to loosen the sludge before draining.
Two birds, one stone.
It will not be as effective as a powerflush, but the cost of the chemical is trifling, and so is the extra effort.
