Elbow Compression Fitting 22mm×¾" pointing the wrong wa
25 Sep 2004
I am fitting a Hudson reed shower and due to space limitations i am having to use a male Iron Elbow Compression Fitting 22mm×¾" into the shower body.. only thing is that when i wind the 3/4 BSP into the shower body it points the wrong direction.
How the hell can i get it pointing in the direction that i want? Do i use a spacer/ or wind on the PTFE
Any help would be great
Iain
you need to but enough ptfe tape on (it wouldnt be my first choice for making the connection though) so that it seals and stiff to turn you shouldnt have to thread it all the way into the fitting to get a good deal that way you still have a couple of turns left on the threads to get the orientation right N.B never loosen the fitting to get the orientation right as it may not seal after.
the best jointing compound for a good seal is Boss White (brand name) and flacks(also called Hemp). the boss is a jointing compound
hope this helps
ptfe tape will not drastically change the finish position of the spout, only harder to wind on all the way. you need to use a copper spacer. 21mm i/d I needed but couldn't find one locally. Ended up filling out a 20mm to size to save myself £10 (mostly postage) from some aerospace co in scotland
If the seal is made by the thread I don't see how a spacer is going to help.
you may finish with the correct orientation, but have a leak.
I agree with eireplumber.
:rolleyes: :rolleyes: :rolleyes:
So it is the thread that makes the seal NOT the end to end seal of the 2 drass bodies making contact and then increasing tension. If thi si correct then the seal does not have to be "tight" for a good water tight seal to occur?
Can i thenuse something like PTFE liquid to get a good seal or is Boss white the bees knees
iain
You should be able to see how the seal is made. If the seal was maent to be the end you would need a sealing washer and the thread would provide the force agaist the seal. But by using the thread only it gives you the adjustment you need.
I had a similar problem this week with an outside tap. If I continued to screw the tap fully home it faced upwards. I had already wrapped ptfe tape on the thread but obviously not enough so more tape made sure it was water tight even though it was not screwed fully home.
hope this helps
Nice to see another old school plumber ;) It`s Flax tho.
