We moved into our house approx. 2 years ago. The house was built in 1832 and is Grade II Listed. We had a Full Building Survey undertaken which confirmed what we expected, that there was dampness would be present in the house. This was expected given the age of the property and the fact that it was empty for sometime prior to us moving in. One room in particular was very damp with dampness visible on the walls up to approx. 3-4ft above the floor. This is a second sitting room and rarely used and therefore dampness can't be attributed to occupancy or use of the room. There is an open fire place with a functional chimney. 2 of the four walls are external wall, which are of solid brick construction c. 15-18" thick. There are no air / brick vents and ventilation through the windows is negligible given secondary glazing units have been fitted.
We installed electro osmosis damp proofing to the full perimeter of the house in Nov 2009. Drying out of dampness was expected to be and has been very slow. In an attempt to speed things up I bought a Ruby Dry Portable Dehumidifier in Oct 2010. This is running 24/7 with some exceptions - basically when I get fed-up emptying the bloody thing. The dehumidifier has a 6 litre reservoir which I empty daily!
That's somewhere in the region of 1000 litres of water. Is this normal, is there that much volume available within the walls to store such a quantity?
I have a 'cheapey' dampmeter which seems to give quite high readings (60-80%) similar to those when we first moved in.
Can anybody shed any light on this matter?
