I am replacing a (mechanically) worn-out bathroom ceiling fan - a straightforward like-for-like replacement. The fan is not a timer type and is wired into the (5 amp MCB) lighting circuit in the usual way via a three-pole isolator (only 2 poles used). There is no separate fuse for the fan circuit but the manufacturers stipulate the fan should be protected by a 3 amp fuse.
Is this normal? The circuits in the wiki show no separate fuse although most of the small bathroom fans I looked at require 3 amp max circuit.
What should I do?
Hughie
What should I do?
Hughie
