I have a Philips low energy light bulb on my landing. From the very first day I put it in I have had a fault with it. If I put this bulb anywhere in the house it doesn't’t do it. If I put the same type and make of bulb from down stairs into the landing fitting that will do the same.
When the switch is turned off one of the three elements in the bulb will flash every 10 seconds then after a minute the other two elements will flash so it gets brighter. After some time the light will stop flashing until the next time it is switched on for any length of time then back off again.
The electrician has passed all lighting circuits when he did the part p. He said he doesn't know what is causing it.
What can be causing this?
