I have a on old blue switchmaster VA1 valve which has packed up. Its just making a grinding valve and not turning at all. I am able to turn it manually by placing a coin in the slot and twisting.
The problem I have is that it is in a very confined and awkward spot and the pipes are in an inverted T configuration . This means that if i was to replace the valve it would mean a lot of new pipework in a hard to get to place.
Does anyone know of
1) anywhere i may be able to get a Switchmaster VA1 motorised valve from.
or
2) Is there a replacement synchron motor available for this switch
or
3) Would it be possible to use the valve in a fixed position - i.e. CH & HW and changed it to just HW in the warmer weather?
Many thanks in advance for anyones help
Alan..
Does anyone know of
or
or
Alan..
