ferroli 700 swiching on by itself
2 Nov 2010
i have a ferroli 700 .it swiches on by its self intermittely.The enginneer has checked thermostat and replaced timer.still the same!! it runs for about 10 minutes and radiators start to warm even though the thermostat is switched off .can anyone help???
It could be several things.
It sounds as if you need a new ( better ) engineer!
Tony
Tony
tell me about it!!! one thing though i am a copier enginner.the relay on the pcb has a fit sometimes.so thinking that??
Check the cold resistance of the sensors.
Also the DHW demand switch.
Thats for a start.
How do I stop the papers sticking together on my old collating copier?
Tony
Thats for a start.
Tony
paper is damp.copiers work off friction so if your paper is in a warm room and at night temp drops the paper absorbs the moistiure causing it to jam in machine or stick togeher.try fresh paper in packet if not that then its the seperation roller worn.hope this helps!!! thanks for the tips!!!!
