Myself and my girlfriend recently opened up the fireplace on our 1930's house.
We intend to use this as an open fire to begin, and perhaps install a woodburner later.
A sweep has confirmed the chimney is sound.
At present, the base of the firebox is rough hardcore - I intend to patch this with sand and cement , and then pour in self levelling floor screed, to include the external hearth (300mm projection on the front), to a depth of around 30-40mm.
I will then tile this using some slate tiles, with a thickness of 10-15mm.
I have raked out the mortar from the bricks inside the firebox and re-mortared with a standard mix bag of sand a cement from a DIY store.
I will then stand a grate on the tiles in the firebox and use as an open fire.
Does this all sound satisfacrtory?
I've read about fire cement, but really not sure how and where this is applied.
Many thanks
Many thanks
