Hi there.
I have recently purchased a glass splashback to fix behind the hob to keep the clean wall. I opted for this rather than tiling as I have seen these used before and look quite smart.
I received the splashback which is hardened glass and has 4 holes pre-drilled.
Only issue is that I now realise that having scanned the wall for electric cables using a detector, I don't think I am going to be able to safely drill the holes necessary to fix it. Really should have thought of that first!!
Does anyone know of any good non-screw methods to fix this splashback? It is a clear glass one so don't want anything that is going to look bad. I am considering using something like no more nails at the points where the holes would be - then I can fix the chrome screw caps into the holes and onto the no-more-nails so that it looks smart. But wondering if anyone can think of a better alternative.
Thanks,
Rob.
Thanks,
Rob.
