Morning,
This is more a thermal / heat loss question than wiring+plumbing (I can do the latter!)
I have a 3 story Victorian terrace house that will be left unoccupied over winter, but I will be leaving the boiler powered, and do not want to fully drain the CW system. The plumbing layout is fairly standard 70s design:
- vented HW (tank in bathroom)
- CW tank in loft (tiled pitch roof - assume moderately but not well insulated) Pre-dates Byelaw 30 - tank has no lid / insulation, pipework has standard expanded foam insulation
- gas boiler in basement. Boiler has no internal frost stat.
- S-plan plumbing (not really relevant, but I mention it just in case)
Last year I set the system up with a programmer that had a 5oC frost setting, programmer is on ground floor (i.e. low point of airspace) I'm concerned that's not enough
So my current thoughts are:
1. Add frost-stat to basement area. The basement is enclosed by the other houses, so I doubt this will click in.
2. Lag the tank. I don't think there's any reason not to.
Here's where's it gets more tricky:
3. Potentially add 'third' frost-stat to top floor of house. (Second one being the one that's on my ground floor programmer already) That's the first question - in my mind the top should always be warmer due to thermal currents. Is that frost-stat a waste of time?
or 4. Put the third frost-stat in the HW cylinder cupboard - the pipework is all exposed there.
or 5. Put heating tape around the pipework in loft space, and put a frost-stat to switch that? (I bet it will run for days as the heating tape won't warm up enough to affect the stat temperature)
Sorry - have realised that's a very long post (almost a night in the pub conversation)!
I think it boils down to whether I believe the loft will go below freezing while the house is 5oC. I have no idea... is it overkill to use heating tape if I already maintain a minimum 5oC temperature? Does covering my house in frost stats work any better than just having one on the ground floor? Any experiences gratefully received!
