Have just discovered that my sealed (ie mains-pressure) HW cylinder (a 7-year-old Vaillant Vantage 200L) has developed a slow leak. Now, as I'm not qualified to work on unvented systems I'm obviously not about to attept a repair myself, but would like to narrow down the problem a bit before I call in a pro, as this could clearly be hugely expensive to resolve.
The tank seems to sit within a snugly-fitted, grey plastic dish about 1" high (see photo in link below), and this dish is full of water and overflowing, and I can't see where the leak is. However, removing the immersion heater cover reveals a spongy seal (see photo), which is sodden, especially below the element. Now AFAICS the best case scenario is that the seal on the flange around the immersion heater has gone, which would be relatively straightforward to sort out; however I'm wondering whether it's possible that the wet sponge has just sucked up water by capillary action from the grey dish below?
http://img.photoamp.com/i/Sf3AQ2RDd.JPG
I don't know anything about the anatomy of the tank inside its outer metal casing, and I wonder if anyone who does might be able to comment on the likely cause of the leak?
