I realise there's lots of info already on these forums concerning the questions I'm about to ask, so please excuse me asking them again. My post is really just to summarise what I plan doing and see if I am definitely applying the right materials and techniques. You'll have to excuse my naivety to all this as I'm not an experienced DIYer by any means! But I'm trying
I am in the process of doing my bathroom. (Actually I have been since February but that's another story ). I have bought marble floor tiles and the plan was to lay these on a plywood base. The floorboards currently in the bathroom are of the 18mm chipboard variety but unfortunately a number of them are water damaged. The one under the bath was completely sodden so I have already ripped that one out. After researching this forum and a number of others on the net I had come to the conclusion that the ideal solution would be to take up all the chipboard flooring and replace this with WBP 22mm plywood and tile over the top.
I am now wondering about the use of Hardie Backer board. I've read through their leaflet and this seems like another ideal solution. I could replace the damaged chipboard flooring with the same and then go over the top with hardie backer board.
The hardie cement board is only 6mm thick. Is this a sufficient thickness to tile over to avoid movement?
There are obviously numerous options of which I see them as being the following:
1) Should I remove existing chipboarding completely and then replace with 22mm ply and tile over.
2) Remove existing chipboard floorboard, replace with 18mm WBP ply and then fit hardie 6mm backerboards and then tile over.
3) Leave good chipboarding and replace water damaged ones with the same new ones. Then fit Hardie 6mm backer board and tile over.
4) Then I guess there is all of the above with the addition of a Homelux membrane (or similar product).
While I'm on the subject of Hardie backer board and Homelux membrane: I was planning on using the Homelux matting onto plasterboard for my shower cubicle. Would I be better using Hardie backerboard (instead of plasterboard. One wall currently has no boarding at all and the other with plasterboard will need removing for pipework anyways) and then Homelux membrane over the top for this application as well? Is that overkill?
Thanks in advance,
Daz
PS. I'm no expert diyer so go easy on me if I've suggested a wrong idea
Thanks in advance,
Daz
