Had a new boiler fitted in summer. No problems with it except that when thermostat clicks on, the boiler fires and heats the house. when thermostat reaches correct temp it turns off boiler.
the problem is the house gets really cold before stat clicks on again and boiler refires. House is constantly going hot and cold.
Boiler is Ideal Logic + 30w . New thermostat is Honeywell T6360B fitted in hallway.
Rechecked wiring and thermostat is wired correctly according to Ideal guide and Honeywell guide. It uses the 3 wire version.
Is there something i can check as it doesnt seem right.
