Hi , i am replacing a automatic airvent , i cut the pipe and the hot water pupmed out i managed to get the speedfit end cap on , now when i am running the hot tap to try to drain it is just trickling out , it will only come out from one tap and it is very slow . Prior to this i turned water of at the mains and the two valves i have in the cupboard were the imersion heater is . Is it a case of waiting to the trickle of hot stops before i try to change the air vent . Thanks
