If there's a hole behind a CU which the cables comes through should this be sealed up? I mean when they are pushed through cavity from meter box. If so what should it be sealed with, is loft/cavity wall insulation to fire reg standards ok?
If you use rockwool, your need to do the cals for bunching, and thermal insulation
Soft set cement or very sandy mortar does the job, as does a dab of bonding. If it's an area that cables will be added to the hole, the trick is to block the hole and not make it impossible to open up again.
